Just install your demo and check my blog i found some errors.This error show on home page display content type and all content moved any position .
Errors:-
[/vc_column_inner][/vc_row_inner][/vc_column][vc_column width=”1/3″]
[/vc_column_inner][vc_column_inner width=”1/2″]
[vc_row_inner][vc_column_inner width=”1/2″]
check my blog
http://www.industriesstory.co.uk/
I’ve checked your site and the homepage it’s displayed fine now: http://screencast.com/t/oa5qJF5k8FM The indicated errors appear when Visual Composer plugin is not installed and the page contains elements which cannot be rendered without VC.
