I contact you because I have some problems with videos in posts.
Editor : OK
On the website :
And, other problem : Block_9
Can you help me please ?
I’m not sure how you implement your videos but you need to try a different method of implementation as the one you use is not responsive. It has a fixed with: http://screencast.com/t/fpnn2u3v so it will display fine in desktop but it will break in tablet and mobile.
As for the block 9, please try to disable all plugins except visual composer, clear cache and reset cdn. This will rule out a plugin conflict. Also if you have any settings on the visual ccomposer row, please reset them to the defaults. You can also recrete it on a blank page and only use block 9 and the slide element. Please male sure top only use these 3 columns https://forum.tagdiv.com/how-to-use-visual-composer/
Let us know how it goes.
The videos are integred with WordPress’s option (Media).
I don’t understand what to do more.Before (with other theme, Avada) it worked.
For Block_9, I’ve disabled all plugin (except Visual Composer) and always the same problem.
Page Test : http://v2.stilejuve.fr/test-block_9/
Thanks for help.
Please send an email at contact@tagdiv.com and provide wp-admin so we can take a look. Also include a link to this topic so we can identify you.
