Viewport Options not working – portrait and mobile are not separate
I’m trying to place an image in a Cloud template for a header I have created.
If I place an image in the portrait view of the viewport options, it automatically replaces the image in the mobile view as well. And vice versa – if I place an image in the mobile view, it replaces it in the portrait view.
I tried using both the Header Logo element and the Single Image element and it does the same for both.
Is this a bug or am doing something wrong?
Hello !
Yes, unfortunately at the moment all the viewports are as 1. You can hide an element on one viewport. You can now edit your mobile viewport if you choose to use a Cloud Library Mobile template. Find out more about it in this topic: https://forum.tagdiv.com/topic/mobile-themes-cloud-library-v10-3-7-update/
