Vimeo Playlist Problem
Hi there,
I’ve been having an issue with my Vimeo playlist which is not showing any videos. The playlist seems a bit unstable.
– When I start a brand new fresh page with the vimeo playlist, and use the demo videos there it is fine.
– When I try and paste the codes to the videos I want to show (115133786, 114927223, 114595743) it is totally blank. I also don’t have any other videos or playlists on this page. See page (http://65c.c5d.myftpupload.com/queens-wharf-precinct/)
I can give you login details to take a look, just let me know where to send it.
Regards,
Eric
Hello ericdavid1,
I have tested on my side with your videos IDs and the Vimeo playlist seems to work as properly, as you can see here -> http://screencast.com/t/pU2djDVakp -> http://screencast.com/t/7RLdpvvT Please ensure that you have correctly followed all the steps which are needed to take in this regard, according to our documentation here -> https://forum.tagdiv.com/video-playlist-2/
Also, please make sure that your untested plugins do not affect your theme and do not generate some unknown issue through the theme. To be sure, please try to disable all the active plugins, leave just Visual Composer to active, clear all cache and install only the plugins that come bundled with our theme and rule out the conflicting plugins.
Thank you for the message!
