Visual composer: a box inside another box
Hi to everyone,
A little qeustion for you please:
I used demo magazine on my home page;
I edited it and i noted that there is a box set 2/3 + 1/3:
inside 2/3 part there is another “box” 1/2 + 1/2
How can I do that?
See the picture:
a 2/3 + 1/3 structure
and the partciular of 2/3 on the left
a box inside another box... how?
You see:
Block 1
Blcok 15
Block 2 + Block 2
How can I insert the two Blcok 2 in the same box of the Blcok 1 and Blcok 15?
Thanks in advacne for your answers
  • This topic was modified 9 years by albertok.
That is a row in row layout. A row can be inserted in a different row, that is the case here
https://www.screencast.com/t/qg1YvT2Qr4W0
https://www.screencast.com/t/1Kx3W7cZG4A
https://www.screencast.com/t/o5Tw47pKs
If you want to place the Block 2 with the other blocks above, simply drag it out and place it there
https://www.screencast.com/t/HZNSqeKl7jy
Place both Blocks 2 there, then remove the empty row that remains or maybe add other elements in it if you want
https://www.screencast.com/t/kEVE560MXv
Perfect! unrderstood!
Thank you very much for yur help mr.Simion 🙂
A.
