Visual Composer activation problem
I’ve just bought newsmag theme from themeforest. When I press to activate visual composer it redirect me to themeforest.
I’ve login but after that it says NO LICENSES FOUND
How can i activate it?
Thanks,
Mesut
Ignore the nag notice. You do not need to ‘activate’ the plugin with the developer to get support.
Just “turn it on” from the plugins panel and start using it 🙂
