Visual Composer Help
we upgraded to newspaper 8 and this time both visual composer and new tagDiv visual composer is activated. We never created a home page since we are using the typical blog layout. All other Category and tag page are also from the previous chosen templates.
Also, we confirm that there is no other page is created with visual composer we had selected only the templates from theme panel.
Can we switch off or deactivate any composer, both or we need to keep both active?
Website: lethow.com
  • This topic was modified 9 years by lethow. Reason: additional information
Hello lethow,
You should use only one from our page builders which you like and it is not recommended to be simultaneously used, sorry! For more information about this, please check the documentation here -> https://forum.tagdiv.com/visual-composer-tagdiv-composer-transition/ -> https://forum.tagdiv.com/tagdiv-composer-tutorial/
