I installed the theme new version v10.3.5 and re-activated all plugins. There are some problems;
TAG Div Composer does not work on cloud templates
All page settings are broken and although I do most of them, the following problems still persist;
footer and other pages (I used cloud templates)
The sidebar of all pages is not visible.
I just checked your website and this is look normal, also the sidebar is displaying in posts -> https://i.imgur.com/kB2A3wY.jpg
If there is still a problem, make sure that you do not have a plugin conflict, please deactivate ALL plugins except tagDiv plugins, also if you are using child theme or cache plugin, deactivate them, clear all cache and try again.
