Visual Composer Problem
Hi there! I´m having a problem with Visual Composer. I can create new pages, but when I attemp to edit it, some rows are hidden, and the “+” button to add new rows isn´t there. How can i fix it? I’m using VC Version 4.3.4 and a child theme of Newspaper 4.6…
http://pausa.com.ar/
Regards!
Not sure why you have this issue, please check this without any plugins active, leave only Visual Composer active, clear cache and check again. Also make sure that all elements are selected from the Visual Composer Settings – http://screencast.com/t/gM3F8N3k
