Visual Composer problem while migrating from Magazinly to Newspaper 6.4
I’ve purchased and installed Newspaper 6.4 on my site using Magazinly, as I’ver read it would be a direct migration process. I’ve installed Visual Composer plugin from Newspaper control panel.
Now Visual Composer codes seem not to be correctly interpreted. You can see the main page appearance under Magazinly theme here: http://postimg.org/image/jye2revtb/
And the same main page appearance under Newspaper 6.4 theme here:http://postimg.org/image/cr7shsvin/
Also, trying to edit the page, Visual Composer toolbox seem not to include the needed items, as you can see here: http://postimg.org/image/se3n8wyof/
I’ve tried to run the script that updates shortcodes from Newspaper 4 format, but it returns an error (no Newspaper 4 found) and now the site is off. No way to access the wordpress admin panel (empty html page returned by the server). Now trying to restore it from backup
Any advice about the Magazinly to Newspaper 6 migration?
Thank you
There is a simple fix,you need to install V6 with a fresh install because it’s like a new theme,people that using newpaper V4 can move over to V6 with out much issues,because it was build for that but not the “Magazinly theme”
So it’s best you delete the theme “Magazinly” and start with a fresh install with V6 with out having a bunch of issues also update ur VC plugin to work with V6…and very important do a BACKUP..
Thank you for your answer, Steven
I switched from Magazinly to Twenty Fifteen theme, deleted Magazinly, instaled and activated Newspaper 6, installed Visual Composer (the last version, included within Newspaper theme, as downloaded yesterday).
Same result as before:
– The page shows as following: http://postimg.org/image/cr7shsvin/
– Visual Composer seem not to have any tagdiv element to add to the page being edited: http://postimg.org/image/se3n8wyof/
¿Any advice about thois?
Please, I need support for migratin my site from Magazinly to Newspaper 6
Thank you
You will need to re-create your home page, sidebars, menus, as they are two totally different themes.
Thank you Chris,
I tried to do so, but Visual Composer does not show any tagdiv block to use on the home page, as can be seen here: http://postimg.org/image/se3n8wyof/
What can be wrong here?
Tagdiv, please, can you give any support about this?
Thank you
Hi Injaki,
Please select all elements from Visual Composer settings to appear and save – http://screencast.com/t/x0eAsRoVN
Thank you Alin,
That solved it. Now I just have to re-create the pages of the site.
