Visual Composer problems
Hello
Show me this today
” To receive automatic updates license activation is required. Please visit Settings to activate your Visual Composer.”
And now?
from the theme docs:
How to Update Visual Composer plugin (WPBakery)
•The theme includes a license for this plugin so you don’t have to buy it.
•You don’t have to activate the plugin license, it’s already activated.
•You can’t update the plugin directly from the it’s producer.
•You don’t have to worry about the plugin update warnings.
ok
I’ve bought wpbakery latest visual composer so I can process my web page. But I still can not process the page is blocked, there is a message that appears as “license expired”. I’ve uploaded many times over 10 hours until now there is still no solution. send the reply please to ariansyah2211@gmail.com
You need to use the version of visual composer included with the theme.
I’ve been using the same version or upload of the same theme, but why do I still have not been able to process the page.
send value API Key , Visual Composer License Key to me at ariansyah2211@gmail.com, now please
give me chat line to Mr. Cris C please , i realy need support about m problem…hurry please.
my editor page is blank (hidden), i dont know the solution…help me please
As Chris stated you need to update your VC plugin from the /plugins folder that was provided with the theme files and use this guide to install/update it: https://forum.tagdiv.com/how-to-update-visual-composer-plugin-wpbakery/
Please also note the following:
    We provide updates on a regular basis, after we test the plugin for theme compatibility we include it in the latest theme update, inside the ../plugins folder
Also please note that we will release an update with the new version of VC as soon as they will fix issues that apparently they have with the current version: http://screencast.com/t/MhULCZhfr
You can see their forum for more info: http://codecanyon.net/item/visual-composer-page-builder-for-wordpress/242431/comments?page=332
