Visual Composer problems
Hey there!
I just bought newspaper theme and i am working with wordpress( should be the latest version). I installed everything but when I want to create a new article i need to activate the Visual Composer.
But after 5 seconds of activation it all stops and you can read that the composer is “forbidden”. Without Visual Composer am I not able to do anything. But it simly doesnt work.
Do I need to do something with plugIn? Has anyone had the same problem?
I would be grateful for your help!
Thanx
We recommend to use Visual Composer only on pages, try to not use it on posts. Also why don’t you use tagdiv composer plugin instead V.C. It has a frontend editor – https://forum.tagdiv.com/tagdiv-composer-tutorial/
If you still have problems using V.C. please send an email at contact@tagdiv.com and provide wp-admin access so we can take a closer look. Also paste a link to this topic so we can identify you.
