Visual Composer Problems
Hi Guys,
Great theme by the way.
I am having a drama with Visual Composer. As you will see here on a site I am doing ” http://www.softwaredesignbiz.com/katrina/
The alignment and CSS Animations are not working. The first paragraph About Us, the single image and the text below it have animations applied to it, but are not working at all.
Please help me out here to get them working. I have used visual composer on other sites I have done with different hemes and the animations work fine.
Regards
Darren
Its working now which is strange.
I activated the child theme and all appears to be working.
As a side note is their a way to implement ” Font Awesome ” Icons both in the menus and throughtout the site?
Re, Font Awesome:
I think the theme uses the built-in icons from Bootstrap 3 (aka “Glyphicons”). Adding Font Awesome would slow down the site a little bit, even if loaded off the CDN.
Still, you could likely simply add this in the appropriate place:
(likely in the header section, and/or in the td speed booster plugin)
<link href="//netdna.bootstrapcdn.com/font-awesome/4.1.0/css/font-awesome.min.css" rel="stylesheet">
Bootstrap 3 glyphs:
http://getbootstrap.com/components/
