having issues when the tagDiv Composer plugin active. The column settings not working inside the row:
https://prnt.sc/p97a4b, https://prnt.sc/p978w8
But working fine when the TagDiv Composer is disabled: https://prnt.sc/p97cxl, https://prnt.sc/p97arh
Using all update version for the theme and all TagDiv’s plugins.
Looking forward to any kind of help.
Hello !
Please note that we do not recommend using 2 page builders on the same page. Also by working with WP bakery on cloud templates may cause issues and conflicts.
Also using wp-bakery on tagdiv built templates will cause issues. We recommend using tagDiv Composer.
Is there any possible way to disabled Tag Div Composer For a specific page/post?
