You can read more about this issue here – http://www.webnots.com/fix-slow-page-loading-waiting-fonts-googleapis-com/ Also you can try this using only necessarily plugins(it may caused by many plugins) and see if you still have this issue. There is also a plugin recommended there to disable google fonts in wp-admin interface – Disable Google Fonts
Hey,
I’m just coming back to this now. The link you gave only tells you how to stop it happening on my browser side.
The first time my site loads after I clear my server cache, it take a very, very log time (over a minute), none of the images load properly and it just says “waiting for fonts.gstatic.com”
Is anyone else experiencing this issue?
I’ve cleared the cache on my server just now so if you go on and have a look you’ll see what i mean.
skyride.
Alin [tagDiv].
Never mind I believe it is a plugin issue.. Its so annoying because it is hard to replicate the issue manually but when I think its fixed it comes back. I just deactivated a plugin, cleared the server cache and it worked fine. But then it still worked fine after reactivating said plugin!
Who knows…
Admin could you please delete my website from my previous post?
