I want to post my business-related news, Sell my business products and write articles about my product-relevant services. Can you please guide how I can set up all these settings in a single domain using a newspaper theme?
You can import the templates for the shop -> https://i.imgur.com/XYKcwHJ.png -> https://i.imgur.com/KIGvpyb.png
Do you want to have also, the homepage like that?
Then you can import the page/template as I said above -> https://forum.tagdiv.com/homepage-how-to-build-and-set-it/ -> https://i.imgur.com/KfmjCKZ.png -> https://i.imgur.com/D9r5hIy.png
Can you please check what’s going on? Unfortunately, I can’t open cloud templates, as you asked for earlier. When I open the cloud template option, it’s just loading and loading. On the other hand, I was checking the plugging option, and something might need to be adequately installed while studying; I found that the theme shows; please reset your key. There is some issue with your theme activation. I reset my key immediately and set going back for theme activation with my theme purchased code. Unfortunately, after putting in the purchased theme code, the submit just loaded, and so on.
Please check my Theme activation key. I reset my key just because I was facing some issues with your theme in cloud templates, and now I am trying to activate my theme again, and it doesn’t work. Please check and resolve asap waiting for your response.
We can take a look so, please contact us via email at contact@tagdiv.com and provide the wp-admin and cPanel login and the license certificate and purchase code.
Hi, Anamaria. I re-install my WordPress, and by the grace of GOD, everything is running well. Thank you
After activating my theme, I am attaching the screenshot of my issue. I don’t know why the error appears red in the attachment, but I remember one thing which might help you guys when I installed the theme the first time; it works great. Easy install and activation, Plugins, etc., but after setting up all the critical steps, I found that the cloud library of the newspaper theme is not working correctly, and it takes too much time to load templates. After a long journey, I could not find any proper solution, so I thought I forgot something while setting up my theme, which caused these issues, so I tried to explore more options. I mistakenly clicked on the unassign option on the theme license page. After that, I continuously faced problems with the attachments containing that issue I was facing from the day first. Secondly, I decided to reinstall my WordPress and start from scratch, and It works, but after setting up everything, I got the same error. I plan to buy this theme because I want to publish my business news, share my business articles, and sell my product and services. I have been setting up my website for a long time. As you guys saw, I purchased my theme in Dec-2022, but I am still on my first step, so please check and guide me if I am doing any wrong because I am lithely fed up with this theme and feel that I am wasting my money and time both now. And especially cloud templates are still loading and loading, and so on. If we cannot do these directly from the theme, please share any backup from where we download these templates now.
– admin url and credentials
– cpanel url and credentials
Also, during the investigation know that we will disable the other non tagDiv plugins.
Our team will take a look and help you ASAP!
Hi, Can you please check why my theme shows the error (An issue has been encountered while trying to validate your license key) same issue happened at the start; at that time, I uninstalled my WordPress and started my work again from scratch, and now the same problem occurs again what is this as I am unable to delete my whole work again and start from scratch I am disappointed in your product and services so please check this issue and resolve this asap.
I am having the same issue with the key validation. I don’t know why it shows that, but it has one of my sites stopped because of that error. Have they found any fix for this??
Hello @sebascalde,
The website works, but you cannot update or install a new prebuilt website or import a new cloud library.
Also, you can contact us via email at contact@tagdiv.com and please provide wp-admin and cPanel access.
