Way to add the same text to bottom of every post
Hi team,
Is there a way or code I can use in order to make the same text appear across every post on my site without having to manually include it.
For example, I might need to have the words: “the content on this page is not financial advice…” at the bottom of every new article that is posted, and all existing articles (200+).
Hi @Montage Creative
In your footer You can add a new raw and write the content there, it will appear across all pages/posts on your site.
That’s the easiest solution which works !
If you need that text to appear only on your posts content and you have the same cloud template assigned, then you should modify only one post and then the changes will be applied automatically on every post that have the same template.
