Hi, we have already inserted keycode on our website to activate the theme, today we have to move the website to another server and so the IP address’llchange. Could it be problems with the license? we hope that this change’ll not cause some losses on theme settings we have done. thank you.
Please, this is an urgent answer we need.
Hello chiara,
Normally the Envato policy allows using a theme only on one install. You can, however, use the theme on a sub-domain if you plan on creating a testing site, but if we are talking about totally different sites with different content, then only one theme per install is legally allowed: http://screencast.com/t/NqzloVgyUJB. In your case, it’s okay if you are using the same site.
Hope this helps!
Thank you for the message!
