Hello. I have problem with weather widget
Weather API error: Error getting remote data for today forecast. Please check your server configuration
I checked theme system status, and I found something matter -> HTTP channel test : all_fail
But, I still don’t know why it doesn’t work.
Could you help me, pls?
Hello gh03083,
I have made some tests on my side with weather widget and it seems to work as expected. Ensure that you are using the latest theme version, clear all your caches and check the results. It should work as expected. Notice that the weather results are coming from API from http://openweathermap.org/
