Hi, I use a plugin for creating “WebP” versions of uploaded images.
Some photos are not converted to this format, I noticed that this only happens with the crop of the photos set in Newspaper theme.
How can I solve?
Correction: only for posts imported with WP All Import, and with crops of your theme.
On the other hand, if I use WP All import I have no problem with WordPress default crops
Hello @marcorroma!
Please make sure your images are uploaded in their full size and set it as full size also as you can see here: https://www.screencast.com/t/Oxue274e
You can use that plugin also/which one is suitable for your needs, but please take care for a future plugin conflict.
the crop of the featured image of the posts is set in the post layout.
I don’t see the setting to choose the crop of the image, and I don’t want to set the crop for each published image (about 100 posts are published a day on my site, by at least 10 users).
Screenshot:
https://i.ibb.co/dbpS2YW/img-crop.jpg
I await support
If you referring to optimizing the images, you can use EWWW Image Optimizer Plugin and activate the lazyload option, and then you will have webp images -> https://www.youtube.com/watch?v=bR5ZY1fpeC4 you can use https://i.imgur.com/oiKd10u.png without Easy IO.
