Website at mobile | too wide – low quality blocks
I would like to ask you for help with some cosmetic changes. When I open my web page http://www.neverskipriding.com at mobile (Iphone 7 plus) there are few things to fix.
I add screen with 4 pictures:
https://www.screencast.com/t/ni6BnWGe
1) normal view it seems everything okey (except the socials)
2) it seems there is plenty of space on the right side of the screen, it is possible to somehow lock it to the center without the mobile theme plugin? (in the end it’s not a huge issue for me)
3) when I see web page at the mobile the blocks have very bad quality preview this is something that I really want to fix and there is a graphics under some “play buttons” as well, never seen before..
4) socials are on the left not at center but I guess its because the settings of the social bars at home page (it’s not huge issue)
I don’t want to use mobile theme plugin, it’s okey like this, just need to fix these few probs (quality preview at blocks is the main thing)
Thanks for every advice
David
1/2. That is not supposed to happen, the page should not display like that on mobile. Something is not functioning properly. Please send us an email at contact@tagdiv.com and provide admin login information so we can take a look at the page structure. Also paste a link to this topic in your email.
3. When setting a featured video the thumbnails are created automatically for that video, and then displayed on block modules. There is no quality processing by the theme. A screenshot from the video will be taken, an the thumbnails will be created from that. If the results are not satisfactory, you could replace the image with a featured image of your choosing, of a higher quality.
4. The mobile theme plugin is optional, you can choose not to use it. The main theme is fully responsive, there will be no issues.
Oki I will
