all method tell me for newspaper theme
which plugin paid or free not matter
what setting from theme panel requard faster
You have a pretty good score on the desktop (92-100). You should increase your performance on mobile.
Improving page speed in WordPress is crucial for providing a better user experience and optimizing your website for search engine rankings. Here are some tips to help you enhance your WordPress site’s page speed:
Optimize Images: Compress images before uploading them to your WordPress site. You can use plugins like WP Smush or EWWW Image Optimizer to automatically optimize images without losing quality.
Utilize Caching: Implement caching to reduce server load and speed up page loading times. WordPress caching plugins like WP Super Cache or W3 Total Cache can generate static HTML files of your pages to serve users instead of dynamically generating them each time.
Minify CSS and JavaScript: Minify your CSS and JavaScript files to remove unnecessary characters and reduce file sizes. This can be done manually or through plugins like Autoptimize or W3 Total Cache.
Enable GZIP Compression: Enable GZIP compression on your server to reduce the size of files sent from your server to users’ browsers. Most hosting providers offer GZIP compression, but you can also enable it through plugins like WP Rocket or W3 Total Cache.
Optimize Database: Regularly clean up and optimize your WordPress database to remove unnecessary data and improve performance. You can use plugins like WP-Optimize to automate this process.
Limit External Requests: Minimize the number of external requests your website makes by reducing the use of external scripts and widgets. Each external request adds overhead to your page’s loading time.
Enable Lazy Loading: Implement lazy loading for images, videos, and iframes so that they are only loaded when they are visible on the user’s screen. This can significantly reduce initial page loading times.
Optimize Server Response Time: Choose a reliable hosting provider with fast server response times. Consider using a content delivery network (CDN) to serve your content from servers closer to your users.
Regularly Update Plugins and Themes: Keep your WordPress core, plugins, and themes updated to the latest versions to ensure compatibility with the latest performance optimizations and security patches.
By following these tips, you can significantly improve the page speed of your WordPress website, leading to better user engagement, higher search engine rankings, and overall improved performance.
Alex, check my website here – eurocom.bg
I did a lot of optimising and I want to say that fast speeds are possible. I have NGINX and have redis and fastcgi also I use WPROCKET. When you optimise things correctly – you get great speeds when pages are cached. However, if you have trouble with noncached pages which was my case – I used Super Speedy Plugins. Without cache pages used to load for 10 seconds, now they load for 1 second without cache, also you can check my search bar – it has incredible speeds with over 500k posts. I will attach a link to the plugins, I left a video review for them and you can see the difference. https://www.superspeedyplugins.com/ (scroll to see my review).
If you want to I can share my wp rocket settings if needed.
im using right now ngnix helper fast cgi cache
and wp super cache plugin
if i active auto optimize then page loading slow and page speed checking server response time getting slower
EWWW Image Optimizer also using to optimize images
we also using object storage to store images
