First of all, after the last update, the footer and header inside singles and archives stacked with the default. I had to clone the archive and the single template and then delete the old ones.
Yesterday i decided to copy a new archive and single template from my dev site. Again, no matter what i tried i had to delete the old archives and single templates for the changes to take effect.
After that, everything was working fine, until few hours ago, all my archive pages stopped updating with the new posts!
I cleared cache, i stopped cloudflare, i cleared cache again, i removed my cache plugin, i checked my database, i repaired my database, i deactivated and activated the cloud library, nothing is working!!
The only way to see the new posts is to open the archive template with the tagdiv composer, all the latest posts are showing there, but only there.
Url of archive page: https://athina984.gr/category/deltio-eidiseon-athina-9-84/ (the update stopped at 19.00)
All the archive templates stopped updating within two hours, this is so crazy!
This is so important, so let me know if you need my credentials
This topic was modified 3 years by
NickSi.
Edit: I deactivated all the plugins and switched the theme, the latest posts are showing, i switched back to newspaper with all the other plugins deactivated, the posts are not showing.
I re installed the td plugins and theme from ftp, nothing changed, i downloaded a new cloud template, not worked. I downgrade to an older version, and yet didn’t work!
The homepage and some widgets are updating just fine, the archive pages not, no matter what
Hello @NickSi!
This is strange! Probably the issue there could be that you had a default template set up and then you need to verify each page to have the cloud one, because it won’t assign the cloud template only if you set it global.
Did you solve the issue now? I suggest you to use only tested plugins with our theme.
Hey Bettina,
I had a cloud template, and tried to replace it with a new one. At theme panel was showing the right template (for categories and archives) and everything was working fine (for a few hours). Then I had to manually choose it for each category to make it work again.
I didn’t change or add any plugins before and after the update of your theme. Everything was working as supposed to be.
Yes, for now it seems to work fine
Thank you for your reply
