What Block Is Suitable For Row With 4 Column?
I try several different blocks, but I still can’t find the right block to use that is suitable for a row with 4 column or 4/4 I guess.
The standard theme blocks were not tested in 4 columns. Only the multi-purpose elements will position properly in 4 columns Try the ‘flex block’ element.
I try with Block 7 using inner Column and it worked. Using Flex block element is also possible.
