Newspaper ver8.8
There are a lot of speed up ways for Template optimization.
Dear support team!
Could you advise what system better to install for NewsPaper 8.8?
WP super cache OR WP Fastest Cache?
I’ve installed WP Fastest Cache – my page speed was increased only 10 points – screenshot of PageSpeed result – https://www.screencast.com/t/m23K4405xc
Any other efficient ideas?
We recommend the WP Super Cache, but that does not mean that other caching plugins will surely not work.
We only made tests with the super cache up to this moment, that is why we know there will be no problem with it and we recommend it. There are plenty of theme users that have other caching plugins.
You can also use Cloudflare for more speed improvements. I found some guides you can use for inspiration
– https://wpdingo.com/setup-wp-super-cache-cloudflare
– https://tutreal.com/wp-super-cache-cloudflare/
Be sure to test the website with online tools, see where you can improve. Using caching and Cloudflare should improve the performance considerably.
