What is simplest way to add breadcrumbs to post style 6?
Hi, updating from 1.1 to 1.301 this weekend.
Curious what would be simplest way to add breadcrumbs to top of the image area for the big image of post style 6?
perhaps add
<?php echo td_page_generator::get_single_breadcrumbs($td_mod_single->title); ?>
block above
<?php echo $td_mod_single->get_category(); ?>
I will try that when I get to it; thought I’d double check if better way to do that 🙂
Yes, you can edit single-template-6.php: http://screencast.com/t/mSKjwXV24I
Result: http://screencast.com/t/IRfXazEdlGEI
Groovy. Thanks for the double double check on that. :_)
