what is that problem? url starting //www
hi, in my website source code, i see that some urls starting with //www
http://prntscr.com/84ydvo
what should i do?
thanks
screenshot broken when I try to look at it.
Check your theme settings in the WordPress “settings” panel to make sure you have the correct domain name set.
If you’re using YOAST, check the settings to make sure you don’t have the wrong setting for “prefer www” or similar.
If using external element like Jetpack, make sure you didn’t register the site as www/.
If you view the WordPress.org codex (docs) for the wp-config.php file, you can also set the “explicit” domain for your site in that which will tell WP it’s always “this way” (e.g., without www).
If you are entering info in widgets like RSS feed, make sure you put in the correct domain URL.
If you are using a CDN, make sure you have the right domain setting there.
  • This reply was modified 11 years by simchris.
hi @Chris
View post on imgur.com
can you check that link again?
Well obviously you have something mis-set as there should be http:// at front of all of those. SO, you should turn off all plugins except VC, and then double check anything in your settings where you have the URL input.
