There just one article typographical confusion.
Problem Screenshot:
https://imgur.com/a/dZRe0FP
Problem url:
http://blog.pinkclassy.com
Hello PINKCLASSY,
I have inspected your source page with this problem and I saw that the excerpt or beginning text of your post hs a lot of Non-breaking space tag ( ) which has a role which does not allow that the code to be broke. It is not necessary to have something like this in your text. Try to delete this text and manually type it and check the results after you have clear all of your caches.
Hi,Catalin
Thanks for your reply,It has been solved perfectly.
Thanks very much
