When CLICK 'Edit with TagDiv composer' its opening HTTP 502 — Unable to Connect
Recently we updated the Newspaper theme Version: 12.6.3 and suddenly started facing the issue of opening TagDiv Composer to edit the template.
https://dailycadcam.com/
If we click on TagDiv Composer tab it shows an error. “Hosting Server Read Timeout
HTTP 502 — Unable to Connect to the Origin Server
Please try again in a few minutes”
I contacted our hosting provider, they are saying the issue is with TagDiv plugin.
Could you please guide me. What could be done to know the roots of error.
thank you
I just checked the website and now is no longer using the Newspaper theme, is a different website.
Also, the mentioned error is usually related to some settings on the server/host – you need to set the wp memory limit, max execution time …
