when i try to edit post some of feature not click able
hello i try to add read more tag on my post & change image feature . Got problem when I try to click on add read more tag on text editor nothing happen . Also image feature when I click to image that i want to change nothing happen as well.
Please advice !!!!
This issue may be caused by a conflict between the theme and some plugins. Try to deactivate all plugins except Visual Composer, clear all caches, purge the cdn if you’re using then test the site again.
Let us know how it goes.
