When sticky menu is active I cant click on post
please go to my site https://zanimljivostioautomobilima.com/category/vesti/ and see whats happen.
When I scrool down and sticky menu is active I cant click on post and open it.
  • This topic was modified 6 years by vlada13.
Is look that you have set on sticky menu the min-height: 100vh; -> https://i.imgur.com/j1JFjgL.png if the settings is remove the posts will work -> https://i.imgur.com/Fv9Ym85.png
Is possible to have set on row and sticky menu, you’ll need to use tagDiv Composer to edit the header template and check the full height option -> https://i.imgur.com/FrqIL6f.png
Let me know the results!
It works 🙂
Thanks for fast reply.
Regards,
Vladan
