When using Visual Composer the right column disappears
Is there a way to keep the sidebar when you use Visual Composer, whenever I try to use it – the sidebar always disappears.
Hello keeno79,
Please notice that if you want to keep the sidebar when you use Visual Composer, you will have to create your sidebar using this plugin and not using the sidebar from widgets area. So, if you need the sidebar for pages using the Visual Composer, you will have to use the Widgetised sidebar, element from VC plugin, like this -> http://screencast.com/t/VFTaoZHoo For more information about how you can make your homepage, please consult our video tutorial here -> https://www.youtube.com/watch?v=LC7iz-v-zIY Also, for more information about how you can use the Visual Composer as properly, please check here -> https://forum.tagdiv.com/how-to-use-visual-composer/
Hope this helps!
