Where can I define class style for some text blocks in my posts?
Hi, sorry, another newbie question. I need to have some special styling on some text blocks such as colored background with padding. I did it with in-line style currently but would love to know that where can I add the CSS style so that elements with the class names will have the same style throughout the site. Also, customized CSS style won’t be wiped out with wordpress or theme update, right? Thanks so much!
There is an option to set custom classes for the available text elements
– https://www.screencast.com/t/NylXzVWjyxo
You can then create your custom design based on the class set there. Custom CSS entered in the them panel will be saved in the database. It will not be lost when the theme is updated.
