Dear support team,
There is a white blank space between the menu and content (first post grid) on the Newspaper mobile theme amp home page (justicemirror.com/?amp=1).
As a result, the first post grid just below the menu bar appears so thin (in width) that it does not look visually appealing. Kindly help me resolve this issue at your earliest convenience.
thanks
For me the layout looks like this https://i.imgur.com/7xkzwvD.png do you want to remove this space https://i.imgur.com/XvlsDmk.png ? for this you must use this custom css:
.td_block_big_grid_mob_1 {
top: -19px;
This code must be set in the theme panel > mobile theme > custom code> css -> https://i.imgur.com/iUnWZED.png
I hope this will help you!
hello,
I added the code but that black-white space between the menu and post grid is still there on the mobile site amp.
I have another site https://hindi.justicemirror.com/?amp=1 where there is no such space as you can see.
I am unable to figure out what is causing that space in https://justicemirror.com/?amp=1
Kindly help
thank you
hello,
I tried again and cleared the cache. though the space has been reduced, the post grid width has also been reduced.
kindly compare site 1 (https://justicemirror.com/?amp=1) with site 2 (https://hindi.justicemirror.com/?amp=1).
I want site 1 post grid below the menu to be like site 2 post grid below the menu on mobile.
thank you.
hello,
I was able to fix that after deactivating the mobile theme > enabling amp on the homepage > reactivating the mobile theme.
thank you.
