There is a white box appears under the ad box. Link: white box on ad box issue. You can also view it directly on my web homepage http://www.jeumpanews.com
Please help. Thank you.
HI
You set a background color for this row: http://screencast.com/t/qtfsAYQqu in Visual Composer. Try to remove it, clear the caches then test the site again.
Let us know ho it goes.
