White Space Problem
After updating to the newest version there are problem with white space before and after block content.
https://www.screencast.com/t/CxjbXSi4
1. More white space after block heading
2. Very little white space before next block heading
Please help to sort out the problem
Hello srampia,
Try to regenerate your thumbnails using the Force Regenerate plugin, clear all your caches and check the results. After this, if your problem is still there, please provide your website URL so I can take a closer look. Notice that if you are using some untested plugins, try to disable all of these and check the results.
Hello Catalin,
Thanks for the support.
Unfortunately those methods did not help to solve the issue.
website url: https://www.lifeday.online
with thanks
That is happening because you seem to have some custom code affecting the block wrap
– https://www.screencast.com/t/MIDdHQ6PC
If I were to disable that code everything looks properly
– https://www.screencast.com/t/NNnnm88doB
Please check in Theme panel->Custom Css section, and modify or remove the code that is affecting the block wrap.
Your suggestion has now helped to solve the problem. I got the desired result by modifying the custom code that affects the block wrap.
Thanks a lot
