Why does the unique id for blocks randomly keep changing!?!
Why is the unique id for blocks randomly changing? I am writing css code to target certain elements and out of nowhere my custom css code will stop working because the unique id generated by your code has changed for the element it was targeting. Under what circumstances does this id change and how can we set static ids.
This is the way our theme is working. But you can set a static class name for each element from the tagdiv Composer in the field called “Extra class”.
