Why is there is a space between a letter and an apostrophe?
I am wondering if someone knows why there is a space between a letter and an apostrophe when the blog post is published and how to fix this? It does not show this before it’s published in the post itself. This is for all blog posts that I publish.
So for example in a case like this https://prnt.sc/vjvv85 there is a space before the apostrophe?
Seems to look fine for me https://prnt.sc/vjvvvn Or maybe I am doing it wrong.
Could you provide an example of this happening? A link to a post/page where it is happening would be helpful, so we can inspect it. Please let us know.
Hi!
Those 2 links don’t go to my site. Pick any blog posts on my site and you will see something like this when there is an apostrophe: They ‘re instead of they’re.
It’s fine when it’s in editor( inside of WordPress at all times), readers see this when the blog post is published.
https://ottawamommyclub.ca/bennyco-celebrates-60-years-as-master-roasters/
Those 2 links I provided were an example of me mentioning that this issue does not happen in my test install.
I see now that it does however happen on your website https://prnt.sc/vklli4
I thought it was because of the apostrophe itself, it seems to look like this https://prnt.sc/vkltkx while typing it should be like this https://prnt.sc/vkluxz
That doesn’t solve it however.
It seems to be something with the font used, very unusual. If I change the font the space is gone https://prnt.sc/vkm41d and if I change it back it reappears https://prnt.sc/vkm2tq
Could you maybe consider using the default Noto Serif font instead of the traditional Chinese version? That seems to solve it, and there aren’t many differences between them. I have set that one at the moment, please check and let me know.
Can you write here as to how to change the fonts on my site?
Is there a basic tutorial for things like this? I had a web designer install the theme and I find it very user unfriendly lol! I love the theme, but it’s not the easiest to work with when you have limited knowledge.
Thanks again!
I also just noticed that it’s not correcting it within the title of the blog post. Can you fix this?
https://ottawamommyclub.ca/diy-santas-workshop-ornament/
Hello !
The fonts can be changed from the website manager here: https://www.screencast.com/t/ZChCFDalc1
For the title issue, We need to take a look and see what happened there.
– admin url and credentials
Our team will take a look !
Hello !
