Why isn't excluding posts by Post ID filter not working?
Hello, still getting used to this theme and already several glitches coming up. For instance, under several blocks, I’m trying to prevent videos from showing up so I used the “-PostId” number, e.g. “-18” (without the quotes), and the videos still keep showing up in those blocks. The alternative is to copy all the categories I do want and that’s a pain, esp. as the theme indicates you should be able to exclude a category with the minus sign and Post ID no. Help!
Hello Soothsayer,
First of all, please ensure that you are using the latest version of the theme which comes bundled with the theme packet and also, installs only the plugins that come bundled with the theme pack and rule out any conflciting plugins. If you want to exclude some categories from Blocks, yo should consult the theme panel option from our guide here -> https://forum.tagdiv.com/block-settings-guide/ Also, clear all your caches, purge CDN files and check the results.
Follow, same here
