Widgets erros:The "td_block_XX_widget" block was affected by errors and may not
The Widgets has many erros:
The "td_block_10_widget" block was affected by errors and may not function properly. Check the developer tools for more details.
The "categories" block was affected by errors and may not function properly. Check the developer tools for more details.
The "text" block was affected by errors and may not function properly. Check the developer tools for more details.
The "search" block was affected by errors and may not function properly. Check the developer tools for more details.
The "td_block_popular_categories_widget" block was affected by errors and may not function properly. Check the developer tools for more details.
It always shows erros
Hello @nwnuyhs!
Install the Classic Widgets plugin and see the results.
Hello Bettina,
You are right,now it’s ok,thank you.
nwnuyhs
