Will Pay For Help PleaSE
I need my header area to be a sticky header from the nav bar up. I also need a custom footer page so the sponsors are not shown against a black background. Ive tried to do this for days and it is much more time consuming and technical then the good ole page builder.
Im sure it is not that hard and someone here probably be done in 20 minutes. I just need to launch the site way behind.
https://lakedigest.com
Hello !
In order to make your header sticky you will have to go here: https://www.screencast.com/t/eHymvFpn
For other custom work we recommend finding a freelancer. You can try finding one here: https://studio.envato.com/
