wirting section width for post
I don’t know how I can explain.
I was editing the old post which is over 2 years old. Therefore I used the “classic editor” plugin.
Then I tried to edit another post disable classic editor plugin.
Then the editing section has become ridiculously narrow.
I have checked the same theme version on my anther website, which is fine.
I also activate the previous theme it was fine.
I deleted parent theme then reinstalled but it’s same.
https://prnt.sc/oqwm7a
This is impossible to write…
And my other website is normal.
https://prnt.sc/oqwmna
Could you please check what wrong with it?
Cheers,
I just did back up.
thank you.
Usually this problem is appearing because of some plugins, please make sure that you do not have a plugin conflict with untested plugins, please deactivate all non theme/tested plugins, also if you are using child theme, clear all cache and try again.
