Dear Support,
I installed vintage_choppers_store!
How to use this page https://demo.tagdiv.com/newspaper_shop_vintage_choppers_store/product/diplomatic-tt/
for different products?
When I duplicated this product I can not find in menu pages. How to added new product to main menu?
I want use Woo Product Template for 3 different product with its images. I changed background image in Row/Css
and I have same background image in different products.
Is it possible to resolve this?
Thank you in advance.
Hello @platamun47 !
You can duplicate the template, change the name, make modifications, and assign it to the other product. Do not set it as global; only the one that you would like to be on all.
Dear Bettina
Thank You!
That means if I have 10 products I must create 10 different Woo Product template…
Where is settings in products to change woo product template?
Thanks a lot!
Hello @platamun47 !
Yes. View a product from Products: https://prnt.sc/mgXmq9MLOyoA and assign a template from there: https://prnt.sc/2WD_Gez7E4D_
You just need to click on the template you need for that product.
Dear Bettina,
Please tell me when I create new product, how to add link to main menu?
You added product diplomatic-tt to main menu like pages! How to did it?
I only can add product to menu if I use custom link 🙁
Thanks a lot!
Hello @platamun47 !
You can add the product to the menu when you edit the menu in the Appearance -> Menus like this: https://prnt.sc/7h2HcvHIQa_R or you can create just a custom link: https://prnt.sc/8W2d3cE45-DW
Dear Bettina,
Thank you for your reply!
Appearance > Menu
In “Add to Menu session” I do not have Products!?
https://imgur.com/a/ArpnwGo
Thank in advance.
