woocommerce Advanced Product Labels extension not showing labels
https:\\casadoprofessor.pt
We have been using newspaper theme with this labels plugin – Woocommerce Advanced Product Labels from BeRocket without any issue untill we have upgraded to your KIDS STORE Shop plugin. After this update, the labels aren’t showing anymore. It is critical for our business that the labels work.
We are using the Cloud library template KIDS STORE ARCHIVE TEMPLATE and the KIDS STORE PRODUCT TEMPLATE.
We noticed that the order of the products it is also Not working.
How can we fix this issue?
Many Thanks
Jose Sá
When you are using the KIDS STORE Shop pre-build theme you are also using the tagdiv shop plugin and it is possible that this plugin that allow you to use cloud template for shop to not be compatible with the extra plugin that you are using (Woocommerce Advanced Product Labels from BeRocket), what you can do is to make a test (it will be better if you can try it on a test website), see if you do not you use a shop pre-build website and tagDiv Shop plugin is not enable, the labels are working?
