Hello, All
I’ve just installed Newspaper and everything looks good. The only problem is with the default Woocommerce “shop” and any category pages. As I’ve been testing the site I’ve added a background image. This is shown perfectly everywhere apart from the pages mentioned above. On these pages the background is being cropped around the header and footer areas – as you can see in this photo:
What is causing this?
:0(
Hello, Again –
I’ve compared the code on the Woocommerce archive pages and a normal page and there is a slight difference. On a normal page the classes assigned to the content div are:
td-main-content-wrap td-main-page-wrap td-container-wrap
Whilst on the Woocommerce templates the classes are:
The missing “td-container-wrap” appears to be causing the issue.
:0/
Perch
I have tested the background on my end but could not find any issues with the category pages.
The woocommerce template does seem top have this issue though.
I will add this to our bug list and fix it in the next update.
You can add that missing class in these 2 files to fix the issue: https://www.screencast.com/t/hYi2Q29DJ
Sorry for the inconvenience
