Woocommerce Infinite Scroll & Speed Booster problem
Two Questions:-
1) As Infinite Scroll for Woocommerce pages does not work on Newsmag, I have added a Woocommerce Infinite Scroll Plugin (http://codecanyon.net/item/infinite-ajax-scroll-woocommerce), but this does not work either? I tested it on Twenty twelve and it works perfectly.
There are 3 wrappers required – are these different for Woocommerce Newsmag?
Here are the instructions:-
Enter here the selector which wrap your products. Leave it empty if you want to use woocommerce default (ul.products)
Pagination wrapper:
Enter here the selector which wrap your pagination menu. Leave it empty if you want to use woocommerce default (.woocommerce-pagination)
Next page selector:
Put here the selector of next page. Leave it empty if you want to use woocommerce default
(.next)
Can I add an alternative to fit Newsmag? or is the Plugin incompatible?
2)
The Add to Cart buttons disappear from my product page when I have tagDiv Speed Booster Plugin activated.
Disappointing.
Is there any way to fix this. I need speed, it was my reason for buying Newsmag.
After asking the Plugin writer I thought I would pass on the correct settings which got it working for me in case anyone else is using this plugin with Newsmag.
next selector: a.last + a
pagination selector: .woocommerce .page-nav
The products wrapper leave it empty as already is.
Thanks for your reply and for getting back to this thread.
