Woocommerce loop shop removal code help
Dear TagDiv,
I been searching the forum for this code you provide to remove Woocommerce loop shop on the default page:
add_action( ‘pre_get_posts’, ‘bbloomer_remove_products_from_shop_page’ );
function bbloomer_remove_products_from_shop_page( $q ) {
if ( ! $q->is_main_query() ) return;
if ( ! $q->is_post_type_archive() ) return;
if ( ! is_admin() && is_shop() ) {
$q->set( ‘tax_query’, array(array(
‘taxonomy’ => ‘product_cat’,
‘field’ => ‘slug’,
‘terms’ => array( ‘null’ ),
‘operator’ => ‘IN’
remove_action( ‘pre_get_posts’, ‘bbloomer_remove_products_from_shop_page’ );
add_action( ‘woocommerce_no_products_found’, function(){
if(is_shop()) {
remove_action( ‘woocommerce_no_products_found’, ‘wc_no_products_found’, 10 );
}, 9 );
Where do I paste them to?
Please help
You need to set the code in functions -> https://www.screencast.com/t/dNHGeLEMd9p
You can check a similar topic -> https://forum.tagdiv.com/topic/customize-woocomerce-homepage/
