Woocommerce More Article Box (More Stories) Removal
I searched around and couldn’t find any leads. It seems irrelative for more articles box to be showing up on woocommerce single products. Is there anyway to remove the more articles from specific pages like these?
Hello Vermino
Unfortunately there is no option for this in the theme, but you can achieve this with a bit of custom css you can add in the theme panel:
.single-product
.td-more-articles-box{
display:none;
This hides the more articles box on single products.
that works, thank you!
