WOOCOMMERCE: On the product you do not see the description.
You can verify?
Site: http://www.bcee.it
https://bcee.it/negozio/
Thank you
Please re-check if you have the description when you edit the product, clear your cache and try again.
If this problem is not solved after that, then we need to take a look and see what happened there.
– admin url and credentials
Our team will take a look!
