Hello, I have tried installing woocommerce however it disables all featured images on the Newspaper Theme. So I cannot see featured images at all and all I see there are blank spaces and even the product image too does not show in woocommerce. When I switch to a default wordpress theme, the images show.
Please how do I fix this issue on the template?
This seems like a js error caused by conflicting plugins. It is most likely not caused by woocommerce but the combination between it and another plugin. Please deactivate all plugins except woocommerce and visual composer, clear your cache and reset cdn files if you use it. This issue is caused by a js error and the lazyload animation. You can deactivate this feature if you want.
Let us know how it goes.
I got this error message:
The TagDiv Invoice plugin and the Aurora API of the active theme must share the same version number. Now, the Theme Aurora version: 1.1 and plugin version: TD_WOO_LABEL_VERSION!
Actually the TagDiv Invoice plugin is not activated for preventing unexpected behaviours.
Any help?
